Design >> Mixed-Signal Design >> Clock divider.
https://designers-guide.org/forum/YaBB.pl?num=1396472620
Message started by Jacki on Apr 2nd, 2014, 1:03pm
Title: Clock divider.
Post by Jacki on Apr 2nd, 2014, 1:03pm
Hi,
   I want to get a clock divider as shown in the figure, does anybody know how to do it with the basic digital logic blocks like DFF, AND gate, OR gate ...
   Thank you.
Title: Re: Clock divider.
Post by Jacki on Apr 2nd, 2014, 1:07pm
The duty cycle is not 50%, I try to use clock divider by 5, or counter to achieve it, but I failed.
Post by AnalogDE on Apr 2nd, 2014, 2:28pm
This looks pretty simple.  You can do it with a counter with output logic that decodes the 'count'.  Logic outputs a '1' when it hits its 'count' that it decodes.  Run that logic and AND it with incoming clock...  That should be it.
Post by Jacki on Apr 2nd, 2014, 5:29pm
Hi AnalogDE,
   Thank you very much for your reply. I don't follow you very well. I will make a test tomorrow. Could you show me a logic structure (building block) as you are convenient?
Post by Jacki on Apr 3rd, 2014, 11:33am
Hi AnalogDE,
   I understand what you mean, thank you.
