https://designers-guide.org/forum/YaBB.pl Design >> RF Design >> why cmos relaxation RC oscillator is frequency stable over varying temperature? https://designers-guide.org/forum/YaBB.pl?num=1396607393 Message started by kanz on Apr 4th, 2014, 3:29am |
Title: why cmos relaxation RC oscillator is frequency stable over varying temperature? Post by kanz on Apr 4th, 2014, 3:29am cmos relaxation RC oscillator was found to be frequency stable when i swept temperature ranging from -40 degree to 100 degree.when i plotted propagation delay of the cmos inverters which i used for this design,it was found to be varying with temperature sweep.Why the change in propagation delay not affecting the frequency of operation ? In the case of ring oscillator ,propagation delay is varying much and it is affecting the frequency ..what point am I missing here ? please help :( |
Title: Re: why cmos relaxation RC oscillator is frequency stable over varying temperature? Post by boe on Apr 7th, 2014, 5:26am Kanz, the frequency depends mainly on the RC time constant, I suppose... - B O E |
Title: Re: why cmos relaxation RC oscillator is frequency stable over varying temperature? Post by analog_rf on Sep 22nd, 2014, 5:38am There could be some kind of cancellation hapenning. I suppose you are using comparators, could be possible that comparators(I/C or RC kind of osc's) are slowing down at 100c and your reference current is increasing at 100c,effectively ending up compensating each other. |
Title: Re: why cmos relaxation RC oscillator is frequency stable over varying temperature? Post by raja.cedt on Sep 22nd, 2014, 7:13am Hi, what's your architecture? is it based smitt-trigger and inverting amp or some capacitor charging and comparator?? I didn't understand why inverter delay comes into picture? @analog_rf..Can you explain your reply bit more clear..Usually compactor is much faster than actual oscillator delay, so I don't think that makes lot of diff. Thanks, Raj. |
Title: Re: why cmos relaxation RC oscillator is frequency stable over varying temperature? Post by analog_rf on Sep 24th, 2014, 6:03am Faster is a relative term. As the Osc frequency reaches say tens of Mhz Comparator delay begins to play a role (say 20Mhz or more).Basically if without applying any cancellation techniques, you end up getting very good freq accuracy, then you are probably seeing some cancellation (eg:comp delay more at 100c causing output freq to decrease and Iref increasing at 100c). One method to isolate causes in such a scenario would be to plot :osc freq vs Temp for atleast 5 temperature points and you would see the freq variation peaking at a point other than 100c. |
