https://designers-guide.org/forum/YaBB.pl Other CAD Tools >> Physical Verification, Extraction and Analysis >> Writing to .csv while doing corner in ADEXL using OCEAN. https://designers-guide.org/forum/YaBB.pl?num=1399349518 Message started by VINAY RAO on May 5th, 2014, 9:11pm |
Title: Writing to .csv while doing corner in ADEXL using OCEAN. Post by VINAY RAO on May 5th, 2014, 9:11pm Hello all, I am doing corner analysis for my LNA and I have got around 15 corners. So I want to record each response in .csv file. I selected only few corners and saved OCEAN from ADEXL and it has got following command for corner as follows. ocnxlCorner( "C0" ("model" "/home/vinay_rao/library/Models/Spectre/L65LL_RVT12_V101_RF.lib.scs" ?section "\"tt\" \"ff\" \"fnsp\" \"snfp\" \"ss\"") ) ) My question is “Are there any options in OCEAN which can track each corner's response and then automatically save it to .csv”? I am trying to avoid FOR loop kind because it becomes very messy if I have to include all the corners. I am new to OCEAN, so any kind of suggestion would be appreciable. Thank you. Regards, Vinay Rao. |
