https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> how to implement a resistor of value around 450M ohms on chip https://designers-guide.org/forum/YaBB.pl?num=1401515366 Message started by jovial on May 30th, 2014, 10:49pm |
Title: how to implement a resistor of value around 450M ohms on chip Post by jovial on May 30th, 2014, 10:49pm HI, I want to how to implement a resistor of value around 450M ohms on chip. I am working on UMC 180nm technology. Can anyone suggest me a simple MOS based circuit for the same? |
Title: Re: how to implement a resistor of value around 450M ohms on chip Post by loose-electron on May 31st, 2014, 2:49pm Simply put - redesign your circuit or method Anything that uses a resistance value that large will not be reliable. |
Title: Re: how to implement a resistor of value around 450M ohms on chip Post by cchen on Jun 4th, 2014, 1:23am If available in your design, trim by digital code may be a choice. |
Title: Re: how to implement a resistor of value around 450M ohms on chip Post by sheldon on Jun 5th, 2014, 3:25pm CChen, |
Title: Re: how to implement a resistor of value around 450M ohms on chip Post by sheldon on Jun 5th, 2014, 3:41pm Jovial, A value of 450 MegaOhms is a very large value to try to integrate. Typical diffused and poly silicon resistors have relatively low sheet resistances, which implies long, thin resistors. Not sure what value of sheet resistance the process has. However, even assuming a very high sheet resistance of 10kOhm/sq, means that the resistor would require 45,000 squares to realize. In addition, to the resistor, you will probably need guard rings around the resistor to prevent leakage further increasing the area. BTW, the 10kOhm/sq assumes the process has a pinched resistor which means that there is a very limited voltage range of operation for the resistor. More practical diffused and poly resistors have sheet resistances on the order of ~100 Ohms/sq. Which implies ~1M squares of resistance. Loose Electron is correct, a design requiring a 450MOhm resistor implies that the design is not appropriate for integration. Best Regards, Sheldon |
Title: Re: how to implement a resistor of value around 450M ohms on chip Post by rf-design on Jun 6th, 2014, 1:32am jovial wrote on May 30th, 2014, 10:49pm:
I suggest to change the implementation of the functional element which need the 450M resistor. The current from a 0.18u max supply of 1.8V on this 450M resistor is 4nA. So this is not far away from leakage currents of the active devices. So the total accuracy comparing leakage and signal is not high. Furtheron the a 450M with 2k/sq high ohmic poly need 225000sq so that the parasitic cap of this resistor could create stability issues if used in an amplifier feedback configuration. An alternative for the function "low current over signal voltage" could be using a much smaller resistor and an active current division. So the total function is a transconductive element with output stage current scaling. |
Title: Re: how to implement a resistor of value around 450M ohms on chip Post by loose-electron on Jun 6th, 2014, 6:17pm What is it that you are trying to do that requires such a device? I am sure that there is a better way or method. |
