https://designers-guide.org/forum/YaBB.pl Design >> RF Design >> Choosing PLL: ADPLL or Fractional N or Integer N https://designers-guide.org/forum/YaBB.pl?num=1402544241 Message started by mixed_signal on Jun 11th, 2014, 8:37pm |
Title: Choosing PLL: ADPLL or Fractional N or Integer N Post by mixed_signal on Jun 11th, 2014, 8:37pm Hi experts, I have the following requirements for my frequency synthesizer PLL center frequency= 700MHz, channel bandwidth=300KHz channel switch time<=100us Phase noise<= -100dBc/Hz@ 1MHz offset I want to make the PLL as low power as possible (<700uW). Which is the most suitable architecture: All digital PLL Integer N PLL (Type 1 or Type2) Fractional N PLL With type2 integer N PLL: Loop BW=1/10th of channel BW=30KHz. This makes it difficult to achieve channel switch time of <100us |
Title: Re: Choosing PLL: ADPLL or Fractional N or Integer N Post by hwa_chan on Jun 20th, 2014, 8:44am digital pll |
Title: Re: Choosing PLL: ADPLL or Fractional N or Integer N Post by loose-electron on Jun 20th, 2014, 7:42pm Your phase noise is the big issue. All digital at that phase noise number? I doubt it. |
