https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> In what case we mixed analog and digital in Verilog-AMS? https://designers-guide.org/forum/YaBB.pl?num=1402651081 Message started by sharpmental on Jun 13th, 2014, 2:18am |
Title: In what case we mixed analog and digital in Verilog-AMS? Post by sharpmental on Jun 13th, 2014, 2:18am I used VerilogA for several mix-signal projects, with ADC, DC-DC, instrumentation amplifiers...such things. In my projects there is always a clear partiton between digital and analog modules. The result is clear, good for function partition, digital engineer could use their familiar tools for verilog, each module could map to final circuit easily...etc. So I got a question, in what case we should or we have to mixed digital and analog in one model? This is the purpose of Verilog-AMS, right? |
Title: Re: In what case we mixed analog and digital in Verilog-AMS? Post by martinm_de on Jun 20th, 2014, 12:18am Mixing analog and digital sometimes makes things easier. E.g. if you have a simple ADC with programmable gain, you put the gain model into the analog part, since it is analog, and you put the gain decoder, which is digital in nature, also into the analog model. If you have e.g. a pipelined ADC where the digital part collects all the bits from the analog part, it may be required to design the digital part using static timing analysis. Here, it would be a desaster to mix mix analog and digital, you better separate analog and digital. Makes it also easier to create a .lib file for the whole block. |
Title: Re: In what case we mixed analog and digital in Verilog-AMS? Post by Ken Kundert on Jun 20th, 2014, 5:59pm Right now your 'analog' blocks are actually mixed signal and you are modeling the digital part of these models with Verilog-A. This is hard and results in slow models. It only makes sense to do that if there is not very much digital to model. Once you learn Verilog-AMS, it is much easier to write these mixed signal models in Verilog-AMS, and the resulting simulations can be much faster. And of course, it you have significant digital (decoding logic, control logic, etc) it is easy and efficient to throw it in too. Finally, you can make really powerful testbenches if you use Verilog-AMS as your testbench. -Ken |
