Measurements >> RF Measurements >> RF connectors
https://designers-guide.org/forum/YaBB.pl?num=1404357290
Message started by mixed_signal on Jul 2nd, 2014, 7:14pm
Title: RF connectors
Post by mixed_signal on Jul 2nd, 2014, 7:14pm
Hi,
What does 1mm, 2.4mm, 3.5mm RF connector signify? Is it the diameter of the pin in male connector?
Title: Re: RF connectors
Post by rfidea on Oct 30th, 2014, 1:04pm
Close guess, the 3.5mm is the inner diameter of the outer conductor (the shield)
