https://designers-guide.org/forum/YaBB.pl Design >> Mixed-Signal Design >> Can I filter Jitter? https://designers-guide.org/forum/YaBB.pl?num=1405929070 Message started by SNIKE on Jul 21st, 2014, 12:51am |
Title: Can I filter Jitter? Post by SNIKE on Jul 21st, 2014, 12:51am Hi members, We have a System clock running at 120MHz, it has 300pS peak to peak jitter. :'( I am designing a pipeline ADC and my sampling frequency is 1MHz. I found that due to aperture uncertanity [jitter] my ADC's performance is limited. Since my sampling frequency is much slower than my main noisy System clock, can I do somekind of filtering and create a new clean Clock? what other methods can I use to improve jitter at low frequencies? Thanks in advance. |
Title: Re: Can I filter Jitter? Post by loose-electron on Jul 21st, 2014, 11:28am You can run a noisy clock into a PLL and get something out of the PLL that averages out the the mean value of the clock coming in, as a function of the PLL bandwidth. Filter jitter? No. Process a jittery clock to get something with less jitter? Yes. I would look into cleaning up your system clock first, somewhere upstream there is a clean clock tied to a crystal. |
Title: Re: Can I filter Jitter? Post by SNIKE on Jul 21st, 2014, 11:41am Thanks for reply. The system clock is a relaxation oscillator. I am not very familiar with clock design. But I guess relaxation oscillators are usually very noisy. Is 300pS OK for relaxation oscillator? Is there some scope of improvement there? "You can run a noisy clock into a PLL and get something out of the PLL that averages out the the mean value of the clock coming in, as a function of the PLL bandwidth." Any prior publications which do this? Do I need a very accurate VCO to design this? |
Title: Re: Can I filter Jitter? Post by carlgrace on Jul 22nd, 2014, 5:34pm SNIKE wrote on Jul 21st, 2014, 11:41am:
Any good text on PLL design will discuss this principle. You do not need a very accurate VCO because the loop high-pass filters the VCO jitter wrt the output of the PLL. (in this narrow sense you can filter jitter, but I'm not contradicting loose-electron). |
Title: Re: Can I filter Jitter? Post by loose-electron on Jul 24th, 2014, 7:05pm Get rid of the relaxation oscillator and go to a crystal based oscillator. Before you try anything else. Using a crystal should fix your problems. |
