Design >> RF Design >> Design OSC
https://designers-guide.org/forum/YaBB.pl?num=1408021507
Message started by AZADBAKHT on Aug 14th, 2014, 5:05am
Title: Design OSC
Post by AZADBAKHT on Aug 14th, 2014, 5:05am
HI guys
i wanna design Frequency Synthesizer.when i design VCO,for OSC Resonance i constrained chose over 750 ohm Resistor.
in you're opinion,my design is valid?
Title: Re: Design OSC
Post by loose-electron on Aug 14th, 2014, 4:06pm
Your question is not understandable.
Post by AZADBAKHT on Aug 14th, 2014, 10:37pm
i'm so sorry loose-electron...
i try to edit my question
Post by aaron_do on Aug 15th, 2014, 1:01am
Hi,
Its more accurate to model the inductor's parasitic resistance in series with the ideal inductor. Is that what you are asking?
Aaron
Post by AZADBAKHT on Aug 15th, 2014, 5:36am
Hi aaron_do
yes,i know this resistance it's parasitic model for tank.
but,in you're opinion i can build an tank with 750 ohm resistance(parasitic model)?
at RLC parallel tank:
R=√(L/C)]*Q      >>>>                (L=1nH , C=10fF)
the formula illustrate for have R=750 must Q is high!!
you think i can build the this tank??
Post by aaron_do on Aug 15th, 2014, 7:04am
Well...you didn't specify your operating frequency or what technology you are using to design your inductors. Where did you get that value for C? It looks like your operating frequency is extremely high...
If your PDK has inductors you can easily check. Otherwise you can use an EM simulator.
Aaron
Post by AZADBAKHT on Aug 15th, 2014, 8:33am
ok ,i working at CMOS-90nm Technology
VCO tuning range is 5GHZ-10GHZ then C capacity is vicinity 40fF-10fF
and i simulate the design and calculate Q
Q is 4-6.66
with this Q i can't design an Tank with 750 ohm loss
nonetheless,in you're opinion i can use a real Resistance in Tank for post layout simulation?
Post by loose-electron on Aug 15th, 2014, 9:06am
At the frequency stated you need a much better model of the inductors and the non ideal parasitics. To get meaningful results you will also need a set of parasitics for every node in the system.
Post by AZADBAKHT on Aug 15th, 2014, 11:16am
tnx a lot sir loose-electron.
how i can set parasitic for every node in system?
my software is cadence.
Post by AZADBAKHT on Aug 15th, 2014, 12:01pm
Post by aaron_do on Aug 15th, 2014, 5:48pm
Since you know what post-layout simulation is, you know how to get the parasitics at all the nodes. However, you need some way to extract inductance too. Try an EM simulator like ADS momentum. As loose-electron implied, if you model the inductor as just an ideal inductor with a parallel resistance at that frequency, your results will be wrong.
regards,
Aaron
Post by AZADBAKHT on Aug 15th, 2014, 9:59pm
ok
understand,can i use the cadence-virtuoso software for design inductor real?
or i must use the ADS?
i don't know how to set the parasitic model at all node in the system in cadence-virtuoso.
you know how that?
tnx a lot  Aaron.
Post by loose-electron on Aug 16th, 2014, 4:23pm
Suggest that you talk with your design team locally about getting better models. Everybody sets up their model sets differently so you need to contact whoever is responsible for the design tools and semiconductor models that you are using
Post by AZADBAKHT on Aug 16th, 2014, 9:40pm
ok
tnx a lot for you're help sir loose-electron
Post by aaron_do on Aug 17th, 2014, 5:31am
Hi,
after creating your layout, you need to create an extracted model using Calibre or Assura. But you need to design the inductors separately using an EM simulator.
Actually these are the something like the basics of using the software, and it would be better if you could find somebody in your own lab who can go over this with you (I'm assuming you're doing this at a University).
regards,
Aaron
Post by AZADBAKHT on Aug 17th, 2014, 7:51am
tnx a lot sir Aaron
really,you help me a lot.
i haven't team and advance lab in my university . so i have very question
i'm sorry for have this problem. :-[
Post by aaron_do on Aug 17th, 2014, 5:10pm
Hi,
So you're the first in your university to work on such a project? That sounds tough, especially for RF work since you will probably need to design the inductors in an EM simulator and then import the s-parameter models.
Assuming you're using Assura, you need to run DRC and LVS. Once your circuit has passed LVS, you need to run QRC. After QRC, an "av_extracted" view will then appear in your library. You need to run simulations on this av_extracted view. You can do so in one of two ways. First you could go to your environment settings in ADE and type in av_extracted at the front of the switch view list. Alternatively you could create a "config" view which will allow you to change the view to simulate block-by-block.
Since this is RF, you shouldn't run QRC on the inductors (unless they are part of the PDK). You need to use an EM simulator to find the S-parameters of the inductor. You can then include the s-parameters in the simulation using the nport component from analogLib...
There are a lot of details I haven't included here because it would be too long. Try running QRC and simulate the extracted view first. Feel free to ask further questions later.
regards,
Aaron
Post by AZADBAKHT on Aug 17th, 2014, 10:39pm
Hi
Yes i'm first person to work at this project.
tnx a lot for you're help.i try to design...
Post by totowo on Nov 16th, 2014, 5:38pm
Hi, AZADBAKHT,
� �" R=√(L/C)]*Q "
� �This equation is only approximately correct @SRF(Self-Resonance Frequency), where omega=1/sqrt(LC). �The SRF is definitely not your oscilation frequency.
� �You should use R=omega*L*Q to estimate the impedance, where the omega is the oscilation frequency you want.
� �The different R values roots in the Series-Parallel Transform.
AZADBAKHT wrote on Aug 15th, 2014, 5:36am:
Hi aaron_do
R=√(L/C)]*Q      >>>>             � �(L=1nH , C=10fF)
Post by AZADBAKHT on Nov 16th, 2014, 9:22pm
Hi totowo,
tnx a lot for your explain.
