https://designers-guide.org/forum/YaBB.pl Design >> High-Power Design >> Variable duty cycle clock generation https://designers-guide.org/forum/YaBB.pl?num=1409932590 Message started by rf_1 on Sep 5th, 2014, 7:56am |
Title: Variable duty cycle clock generation Post by rf_1 on Sep 5th, 2014, 7:56am Hi, I am trying to do a "Verilog - A " model of a block which takes in a control voltage (duty cycle = d ) and a 50% duty cycle clock. as input. The output of this block is a clock with duty cycle 'd'. I am not able to figure out how to go ahead with this problem. I have looked into the following post http://www.designers-guide.org/Forum/YaBB.pl?num=1138941612/15 Please advise Thanks ( |
Title: Re: Variable duty cycle clock generation Post by loose-electron on Oct 20th, 2014, 3:39pm integrate the square wave - gives you a triangle wave use the duty cycle value to set a comparison level. switch states when the two signals equal in value. |
