https://designers-guide.org/forum/YaBB.pl Simulators >> RF Simulators >> pnoise "Add specific Points" Limit https://designers-guide.org/forum/YaBB.pl?num=1410554024 Message started by simsim on Sep 12th, 2014, 1:33pm |
Title: pnoise "Add specific Points" Limit Post by simsim on Sep 12th, 2014, 1:33pm I am running pnoise to simulate flicker noise. I add specific points at 10Hz increments for about 4kHz. However, when ADE is run, the simulator seems to truncate the number of points. Much fewer of the points are simulated. Is there a limit in "Add Specific Points" (or the "values" parameter in the text netlist)? |
