https://designers-guide.org/forum/YaBB.pl Modeling >> Behavioral Models >> Modeling dependent current source. https://designers-guide.org/forum/YaBB.pl?num=1417259413 Message started by anas.iftikhar on Nov 29th, 2014, 3:10am |
Title: Modeling dependent current source. Post by anas.iftikhar on Nov 29th, 2014, 3:10am Hi, How should I model a voltage-controlled-current source in Verilog-A? Need help. Regards. |
Title: Re: Modeling dependent current source. Post by Geoffrey_Coram on Jan 5th, 2015, 1:04pm What have you tried? How complicated is the equation? This is a vccs: I(a,b) <+ V(c,d); |
