https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> OCEAN: plot a waveform without close it https://designers-guide.org/forum/YaBB.pl?num=1418190878 Message started by newic on Dec 9th, 2014, 9:54pm |
Title: OCEAN: plot a waveform without close it Post by newic on Dec 9th, 2014, 9:54pm Hi I tried to plot a waveform across corners using ocean script. It is able to plot of the graphs across corners. However the waveform is closed instantly after the run is completely run. How could I maintain the plot result without close it? |
Title: Re: OCEAN: plot a waveform without close it Post by newic on Dec 12th, 2014, 11:12pm any expert can comment? |
