https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> ldo circuit https://designers-guide.org/forum/YaBB.pl?num=1426850361 Message started by ranjang on Mar 20th, 2015, 4:19am |
Title: ldo circuit Post by ranjang on Mar 20th, 2015, 4:19am Hi, I have to design a LDO circuit.I have created the circuit like below .Will it work as LDO. [img][/img] |
Title: Re: ldo circuit Post by loose-electron on Mar 21st, 2015, 9:50pm D1 has no bias current Output transistor has an undesirable Vbe drop voltage in the control path This is not an LDO architecture. Please go do some academic research to get started. |
