https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> How to ensure sigma-delta DAC output to be monotonic? https://designers-guide.org/forum/YaBB.pl?num=1427331293 Message started by neoflash on Mar 25th, 2015, 5:54pm |
Title: How to ensure sigma-delta DAC output to be monotonic? Post by neoflash on Mar 25th, 2015, 5:54pm I have an over-sampled DAC design with 20-bits input to modulator input and 8-bits output to DAC. Then LPF to remove quantization noise. The DAC is segmented and is subject to mismatch. My question is that how to specify the linearity of this 8-bit segmented DAC to ensure that the final output of this system is monotonic? Thanks, Neo |
