Title: Implementation of HR neuron model using analog computer technique
Post by zulqar on May 16th, 2015, 11:24pm
Hi Everyone,
I am simulating(using HSPICE) HR neuron model using analog computer technique but I am not getting the required response. If anyone can figure out what might be the problem , I will be extremely thankful. I am using ALM124 model of opamp and MLT04 model of multiplier.
Code:
***HR***
Vdd 100 0 DC 10 Vss 99 0 DC -10 Vconst 7 0 1.5 Vbias1 1 0 DC 1 Vbias2 12 0 DC 1 Vbias3 14 0 DC 1 Vbias4 4 0 DC 1 Vref1 15 0 -1 Vref2 16 0 1
.options post .tran 1m 500m
X1 1 2 3 100 99 ALM124 RxI 7 2 873k Rxy 8 2 110k Rxz 9 2 330k Rxx2 10 2 611 Rxx3 11 2 15 Cx 2 3 0.01uF ic=0
X4 4 5 6 100 99 ALM124 R1 3 5 10k R2 5 6 10k
X5 3 3 0 20 100 99 MLT04 X6 20 3 0 21 100 99 MLT04 E1 10 0 20 0 2.5 *As output of MLT04 Vout=0.4Vin^2 , so output is amplified to get Vout=Vin^2 E2 11 0 21 0 -6.25 *As output of Cubic Generator is Vout= 0.16Vin^3 , so output is amplified and inverted to get Vout=-Vin^3
X2 12 13 8 100 99 ALM124 Ryy 8 13 22k Ryx2 10 13 73 Rye 15 13 522.8k Cy 13 8 0.1uF ic=0
X3 14 15 9 100 99 ALM124 Rzz 9 15 10.5k Rzx 6 15 1.8k Rzh 16 15 13.2k Cz 16 15 100uF ic=0
.MODEL ALM124 AMP + C2= 30.00P SRPOS= .5MEG SRNEG= .5MEG + IB= 45N IBOS= 3N VOS= 4M + FREQ= 1MEG DELPHS= 25 CMRR= 85 + ROUT= 50 AV= 100K ISC= 40M + VOPOS= 9.5 VONEG= -9.5 PWR= 142M + VCC= 10 VEE= -10 TEMP= 25.00 + PSRR= 100 DIS= 8.00E-16 JIS= 8.00E-16
* MLT04 SPICE Macro-model Rev. A, 12/93 * JCB / ADI * * Copyright 1993 by Analog Devices * * Refer to "README.DOC" file for License Statement. Use of * this model indicates your acceptance of the terms and pro- * visions in the License Statement. * * Node assignments * X-input * | Y-input * | | Ground * | | | W-output * | | | | Positive supply * | | | | | Negative supply * | | | | | | .SUBCKT MLT04 3 4 2 1 99 50 * * X AND Y INPUT STAGES * V1 3 20 10.5E-3 C1 20 2 3E-12 R1 20 2 1E6 I1 20 2 2.3E-6 V2 4 21 10.5E-3 C2 21 2 3E-12 R2 21 2 1E6 I2 21 2 2.3E-6 * * MULTIPLIER CORE * G1 98 22 POLY(2) (20,2) (21,2) (0,0,0,0,0.4E-6) R3 98 22 1E6 C3 98 22 1E-15 * * INPUT STAGE * I3 99 28 1E-4 Q1 24 1 26 QP Q2 25 23 27 QP R4 50 24 11635 R5 50 25 11635 R6 26 28 11119 R7 27 28 11119 E1 23 98 POLY(1) (22,98) -10E-3 1 * * GAIN STAGE AND DOMINANT POLE AT 145HZ * EREF 98 0 POLY(2) (99,0) (50,0) 0 0.5 0.5 G2 98 29 (24,25) 8.59E-5 R8 29 98 5.82E8 C4 29 98 1.89E-12 D1 29 30 DX D2 31 29 DX V3 99 30 2.2 V4 31 50 2.2 * *POLE AT 30MHZ * G3 98 32 (29,98) 1E-6 R9 32 98 1E6 C5 32 98 5.31E-15 * * OUTPUT STAGE * R10 99 1 80 R11 1 50 80 G4 1 99 (99,32) 12.5E-3 G5 50 1 (32,50) 12.5E-3 D3 32 33 DX D4 34 32 DX V5 33 1 0.72 V6 1 34 0.72 G6 98 35 (1,32) 12.5E-3 D5 35 36 DX D6 37 35 DX V7 36 98 DC 0 V8 98 37 DC 0 F1 99 50 POLY(2) V7 V8 3.65E-3 1 1 * * MODELS USED * .MODEL DX D .MODEL QP PNP(BF=143) .ENDS
.end |
