https://designers-guide.org/forum/YaBB.pl Simulators >> AMS Simulators >> +mts in ams https://designers-guide.org/forum/YaBB.pl?num=1432313230 Message started by rajdeep on May 22nd, 2015, 9:47am |
Title: +mts in ams Post by rajdeep on May 22nd, 2015, 9:47am Hi Guys, How can I netlist with a spice model in AMS? The way I am doing this in spectre only is by adding this model to pspice model list and adding +mts in environment option. All this can be done via the ADE-L gui. Now how do I do the same in AMS? I cannot find a place to add this +mts option, and when I try to netlist it is asking me to add this option. But where? Thanks Rajdeep |
Title: Re: +mts in ams Post by AMS_ei on Apr 18th, 2017, 9:55am Hi Rajdeep, I just saw this post now. I am not sure if you have got this answer. There is a command called "runams" through which you can generate netlist from schematic. runams -lib <library_name> -cell <cell_name> -view config -netlist -rundir top_run This will create a netlist file called "netlist.vams" inside top_run directory. Hope this helps. Thank you. Kind regards. |
