https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> 2nd order distortion in a ideal sigma delta modulator https://designers-guide.org/forum/YaBB.pl?num=1436466023 Message started by xlowen on Jul 9th, 2015, 11:20am |
Title: 2nd order distortion in a ideal sigma delta modulator Post by xlowen on Jul 9th, 2015, 11:20am Dear All, I built a 3rd order feedforward 1-bit DT sigma delta modulator in simulink with ideal integrator and quantizer. When I applied small input signal (-40dB), 2nd order distortion appears at the output spectrum as shown in attached fig. When I apply large input signal (-3dB), usually I can only see 3rd order distortion, which comes from the nonlinearity of 1-bit Qunatizer. Can anyone give some insight about why 2nd distortion shows up when small signal is applied? [img][/img] Thanks, xlowen |
Title: Re: 2nd order distortion in a ideal sigma delta modulator Post by RobG on Jul 10th, 2015, 8:10am 100dB SFDR and 145 dB down... maybe somebody sneezed during the simulation :D I don't think the white noise approximation for quantization noise is as accurate for small signals. Perhaps that is it, but it is a really small error. |
Title: Re: 2nd order distortion in a ideal sigma delta modulator Post by xlowen on Jul 11th, 2015, 1:43am Yes, especially one-bit quantizer is quite nonlinear. In fact I am expecting some tones show up which relates with sampling frequency, instead of signal dependent distortion. It really surprised me! :o |
