Simulators >> Circuit Simulators >> Plotting data failure while running transient simulation
https://designers-guide.org/forum/YaBB.pl?num=1443857388
Message started by petitidiot on Oct 2nd, 2015, 11:29pm
Title: Plotting data failure while running transient simulation
Post by petitidiot on Oct 2nd, 2015, 11:29pm
Hi guys,
I am not sure if it's appropriate to post this issue here. But it's really annoying!
To run a long transient simulation, �plotting data while running sometimes failed and the error message is "No valid waveforms for plotting". I use ic616, and output data format is PXL. As long as I stop the simulation, waveforms can be loaded. I have tried to restart virtuoso, but it still could not plot waveform while running.
For more information, i have set strobeperiod in the transient options. Is it related to the problem?
Thanks!
