https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> 1/f noise in Cadence. https://designers-guide.org/forum/YaBB.pl?num=1444308189 Message started by saqibshah on Oct 8th, 2015, 5:43am |
Title: 1/f noise in Cadence. Post by saqibshah on Oct 8th, 2015, 5:43am I am trying to simulate an integrator in Cadence, and look at the thermal noise of the opamp. However one of the problems is that CAdence usually takes 1/f noise into account as well while looking at the output noise. Is there anyway to make Cadence ignore 1/f noise and just look at the thermal noise generated by the opamp? |
Title: Re: 1/f noise in Cadence. Post by Geoffrey_Coram on Nov 6th, 2015, 7:31am If you have access to the model files, you could try to turn off the flicker noise in the model cards (kf=0 in some models). |
