https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> OTA https://designers-guide.org/forum/YaBB.pl?num=1445686545 Message started by yo_misma on Oct 24th, 2015, 4:35am |
Title: OTA Post by yo_misma on Oct 24th, 2015, 4:35am Hi, I need to solve the attached exercise about a simple OTA. I think it is very basic theoretical exercise, but I have been working with digital electronics so I have forgotten all about analog issues :-[ Especially, I would like to know about how to study the stability of this simple OTA. I will be most grateful if you could solve the exercise. Thanks in advance :) |
Title: Re: OTA Post by Tako on Oct 30th, 2015, 6:19am I can help you a little with architectures, but I imagine this task could be easily done by Google. Here you'll find examples of opamps which can serve as OTA: http://www.mtcmos.com/opamp/ 1. http://www.mtcmos.com/class-a/ 2. http://www.mtcmos.com/class-a-cascoded/ 3. http://www.mtcmos.com/class-a-folded-cascode/ I think you can carry all the exercise easily using books like Baker, Razavi, Maloberti etc. Here you will find examples of books: http://www.designers-guide.org/Books/ |
Title: Re: OTA Post by Rochester on Nov 25th, 2015, 12:11am You can read E.Allen's CMOS Analog Circuit Design.In chapter 6 it provide detailed OTA design and test method. Hope it can help you :) |
