https://designers-guide.org/forum/YaBB.pl Design >> RF Design >> Differential Quadrature Signal Generation of Low Power https://designers-guide.org/forum/YaBB.pl?num=1449769268 Message started by cheap_salary on Dec 10th, 2015, 9:41am |
Title: Differential Quadrature Signal Generation of Low Power Post by cheap_salary on Dec 10th, 2015, 9:41am I would like to generate fully differential quadrature signals of 950MHz using PLL Frequency Synthesizer from 1900MHz differential VCO with low power. Currently, I realize this by D-FF based on master-slave latch structure using CML. However current consumptions are fairly large. Alternate idea I have is using two D-FFs based on TSPC where one is rising edge triggered and the other is falling edge triggered. And I use two inveter and two buffer after them for generating fully differential quadrature signals, i, ib, q and qb. However this scheme is pseudo differential. Quadrature VCO can not be candidate. I use 0.15um-CMOS of vdd=1.5V. If you know good technique, could you share it with me ? |
Title: Re: Differential Quadrature Signal Generation of Low Power Post by raja.cedt on Dec 10th, 2015, 12:48pm use poly phase filters--- |
Title: Re: Differential Quadrature Signal Generation of Low Power Post by loose-electron on Dec 14th, 2015, 10:06pm agreed - poly phase or another reactive filter network structure |
