https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> Voltage reference blocks https://designers-guide.org/forum/YaBB.pl?num=1450232795 Message started by baab on Dec 15th, 2015, 6:26pm |
Title: Voltage reference blocks Post by baab on Dec 15th, 2015, 6:26pm Could anyone explain how these voltage reference blocks operate and how they are used in analog IC design? |
Title: Re: Voltage reference blocks Post by raja.cedt on Dec 16th, 2015, 8:45am Left circuit: One typical application is Vth+(N*vdsat) generation commonly used in cascade bias circuits. N in this expression can be programmed by adjusting top device size(this device will be in triode region). For simple cascode bias, we need Vth+2vdsat, for that 1/3 of the bottom device would be suffices. Right circuit: 1. This is nothing but a diode connected transistor with less vds---if you bias the top device properly 2. Source follower with improved o/p impedance due to -ve feedback if you apply input at the top deice gate Refer Gray and Mayer book, you will find excellent explanation of these. Best Regards, Raj. |
Title: Re: Voltage reference blocks Post by baab on Dec 17th, 2015, 12:49am Hi, Thanks for the reply. I am trying to get a copy of the book. I will read it and ask you more after completing it. |
