https://designers-guide.org/forum/YaBB.pl Design >> RF Design >> Question on phase noise Sphi and normalized noise power L https://designers-guide.org/forum/YaBB.pl?num=1455630464 Message started by seekconfessor on Feb 16th, 2016, 5:47am |
Title: Question on phase noise Sphi and normalized noise power L Post by seekconfessor on Feb 16th, 2016, 5:47am Referring to the paper "Predicting the Phase Noise and Jitter of PLL-Based Frequency Synthesizers", the normalized single-sideband noise power L and the phase noise Sphi has the relationship: L=Sphi/2. But I have some confusion on these two parameters. Question 1: when we are talking about a VCO's phase noise , i.e. -95dBc/Hz@100kHz off, this value means L or Sphi? Question 2: The spectre's Pnoise simulation of a VCO circuit can get a phase noise result, this result means L or Sphi? best regards. |
Title: Re: Question on phase noise Sphi and normalized noise power L Post by Ken Kundert on Feb 16th, 2016, 1:40pm The answer is in the units. L is a normalized noise. The units you give are dBc, which is the noise power normalized to the carrier power. If the units in dBc it's L. The phase noise function in ADE is misnamed. It is really the normalized noise. It makes no effort to extract the phase noise. It it the total SSB noise power relative to the carrier power. However, if you apply it to the output of an oscillator at a frequency where the phase noise dominates, you get what you want. -Ken |
Title: Re: Question on phase noise Sphi and normalized noise power L Post by seekconfessor on Feb 17th, 2016, 7:27am I've got the points, Thanks for your reply. |
