https://designers-guide.org/forum/YaBB.pl Analog Verification >> Analog Performance Verification >> What can we do with "subckts","instance", "model" and "output" results? https://designers-guide.org/forum/YaBB.pl?num=1456162674 Message started by tzg6sa on Feb 22nd, 2016, 9:37am |
Title: What can we do with "subckts","instance", "model" and "output" results? Post by tzg6sa on Feb 22nd, 2016, 9:37am After a spectre simulation the results() command returns with results I do not know how could be used. Code:
I do not know "subckts", "instance", "model", "output", "primitves" and "designParamVals". What data is stored in these simulation results and how could I use them? I have not found any reference in the documentation :( but I am curious what tricks could be done with these. It would be enough to point me to the appropriate documentation. Thanks! |
Title: Re: What can we do with "subckts","instance", "model" and "output" results? Post by Geoffrey_Coram on Feb 22nd, 2016, 11:45am Try "spectre -help info" |
