https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> Error while compiling a circuit including a verilogA model https://designers-guide.org/forum/YaBB.pl?num=1457018913 Message started by dollysi on Mar 3rd, 2016, 7:28am |
Title: Error while compiling a circuit including a verilogA model Post by dollysi on Mar 3rd, 2016, 7:28am Hello everyone, I am designing a circuit which includes latches and a verilogA model of a memristor. After compiling; following error appears in AMS Result browser: ERROR 256: In file "./latch.cir" line 227: + OBJECT "YI30": The sign : is missing after keyword MODEL . latch is the name of my schematic circuit which includes YI30 (which is my verilogA memristor model). I am very new at this so I am having a lot of trouble compiling this. :) |
Title: Re: Error while compiling a circuit including a verilogA model Post by Geoffrey_Coram on Mar 3rd, 2016, 11:57am Without seeing any of your files, we'd be guessing blindly. At least show us line 227! |
Title: Re: Error while compiling a circuit including a verilogA model Post by dollysi on Mar 3rd, 2016, 12:03pm The latch.cir file is automatically generated file. I think no change should be made in that, but I guess the verilogA code (which I am linking) has some problem. http://webee.technion.ac.il/people/skva/Memristor%20Models/Verilog-A/memristor%20model.txt This is my verilogA code. Even if I use this model with other circuit, the same error is being displayed. (filename.cir ) |
Title: Re: Error while compiling a circuit including a verilogA model Post by Geoffrey_Coram on Mar 4th, 2016, 7:04am I opened the Verilog-A file and found this line: parameter real model = 0; It's not on line 227, and MODEL isn't a keyword in Verilog-AMS, but I wonder if the simulator you are using has a problem with it. The netlist you sent me by PM did not include an instance of the memristor, only a voltage source. I suppose you specify a value for the parameter 'model' on the instance line. I would suggest you rename this parameter to "model_type" and see if that solves the problem. |
