https://designers-guide.org/forum/YaBB.pl Other CAD Tools >> Physical Verification, Extraction and Analysis >> X Y snap spacing for layout window https://designers-guide.org/forum/YaBB.pl?num=1457370206 Message started by mixed_signal on Mar 7th, 2016, 9:03am |
Title: X Y snap spacing for layout window Post by mixed_signal on Mar 7th, 2016, 9:03am Hi, In display options form of Virtuoso layout window there are 2 entries X snap and Y snap. Which documents from foundry contain these information? Can anyone suggest me for TSMC 65nm? |
Title: Re: X Y snap spacing for layout window Post by ULPAnalog on Mar 7th, 2016, 10:34am Hello This information is required to avoid off grid errors. Foundries can typically snap their mask dimensions to a certain scale. This will be part of the DRC rule manual and also you should find it in the rule deck. |
Title: Re: X Y snap spacing for layout window Post by ULPAnalog on Mar 7th, 2016, 10:36am Oh by the way, I think it is 5nm (0.005, when units are set to um in Virtuoso layout) for the process you have asked for. |
Title: Re: X Y snap spacing for layout window Post by Jelena on Dec 6th, 2016, 11:47pm You can always check it in your techfile by running a SKILL command in CIW: Code:
(basically what it does is call the techfile and render the info for you if I understood correctly myself) it should output a value in um |
