https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> Pin annotation https://designers-guide.org/forum/YaBB.pl?num=1457611315 Message started by robotist on Mar 10th, 2016, 4:01am |
Title: Pin annotation Post by robotist on Mar 10th, 2016, 4:01am Hello. My name is Kim. If I have instance named I0 and I want to save current #1 pin(pin name is GND). So I use ADE-Outputs-To Be Saved-Select On Schematic. But there is only save I0:1 not I0:GND in netlist. Surely using cdsTerm(), I can spectre simulation. But I want simulation other tool with only spectre netlist. Is there any way to save pin name(I0:GND) instead of pin number(I0:1) in netlist? |
Title: Re: Pin annotation Post by ULPAnalog on Mar 10th, 2016, 10:29am Hello I am unable to follow what exactly you wanted from your post. Could you post a schematic to get a better idea. Thanks and regards |
