https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> High speed cmos divider with large divide ratio https://designers-guide.org/forum/YaBB.pl?num=1459958505 Message started by msl on Apr 6th, 2016, 9:01am |
Title: High speed cmos divider with large divide ratio Post by msl on Apr 6th, 2016, 9:01am Hi, Does anyone here have experience of designing a say cmos0.13um divider with input signal at 2GHz and a divide ratio at 1-16,383? The input speed is too high to synthesize the divider using RTL codes. Thanks CC |
Title: Re: High speed cmos divider with large divide ratio Post by loose-electron on Apr 7th, 2016, 5:18pm msl wrote on Apr 6th, 2016, 9:01am:
You will end up doing an analog-centric design for a predivider, using current mode (aka ECL, PECL, current steering) logic, to get the divider down to something that can clock conventional CMOS logic, after a suitable level shifting circuit. |
