https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> gm/id method https://designers-guide.org/forum/YaBB.pl?num=1460225504 Message started by JARVIS on Apr 9th, 2016, 11:11am |
Title: gm/id method Post by JARVIS on Apr 9th, 2016, 11:11am Hi, I'm using gm/id transistor sizing approach to design a low power opamp. I have a few questions regarding the same. 1) I biased the input transconductances in moderate inversion by choosing the gm/id of the differential transistors = 18, but while running dc simulation in cadence these transistors are shown to be biased in region 2 even though I get required gm. Is this correct? Will the transistors ever be in region 2 if they are in moderate inversion? |
Title: Re: gm/id method Post by ULPAnalog on Apr 9th, 2016, 11:38am Yes it is correct. It differentiates between strong inversion saturation and weak inversion saturation through region parameter being 2 and 3 respectively. For a gm/Id of 18 I would expect it to be on the verge of 2 and 3. You should see op region as 3 if you try to resize in such a way that gm/Id is around 22-25. |
Title: Re: gm/id method Post by JARVIS on Apr 9th, 2016, 11:59am okk thanks. while sizing the transistors in the folded cascode, I used Vov = 2*id/gm and found the sizes from the gm/id lookup table. Since I used worst case condition currents, the dc simulation shows these transistors to be biased in region 2 but gm/id = 18 (since the current is less than worst case current) which implies that these transistors are close to subthreshold under normal bias conditions. Will this be a problem as these transistors should biased in strong inversion? |
Title: Re: gm/id method Post by ULPAnalog on Apr 9th, 2016, 1:30pm It depends on what your tolerances on specifications are. Or you could over design the transconductor stage so that it meets the specs even under worst case conditions. |
