https://designers-guide.org/forum/YaBB.pl Modeling >> Behavioral Models >> Two-Dimensional Arrays in Verilog-A https://designers-guide.org/forum/YaBB.pl?num=1460656621 Message started by AA on Apr 14th, 2016, 9:57am |
Title: Two-Dimensional Arrays in Verilog-A Post by AA on Apr 14th, 2016, 9:57am Hi everyone! I need a two dimensional array of real numbers in my analog model. I googled, but unfortunately found nothing. The only related thing was in the digital verilog domain when creating a register file. That does not help in my case. Anyway, I borrowed an idea from the compilers course, in which you can simulate 2D arrays using 1D. However, this is kind of not neat, and I wonder if there is a better way of doing it. Any idea? Thank you all. |
Title: Re: Two-Dimensional Arrays in Verilog-A Post by Geoffrey_Coram on Apr 21st, 2016, 11:50am Did you check the Verilog-AMS Language Reference Manual? I opened up the latest (version 2.4) and searched for "array" and immediately found "3.4.8 Multidimensional parameter array examples" in the table of contents. And in section 3.2, there's this example: real vtable[0:16][0:7][0:64]; // a multidimensional real array |
