https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> plot current of output node in frequency domain in Cadence https://designers-guide.org/forum/YaBB.pl?num=1460664340 Message started by rames on Apr 14th, 2016, 1:05pm |
Title: plot current of output node in frequency domain in Cadence Post by rames on Apr 14th, 2016, 1:05pm Hello, I want to plot current of output node in frequency domain with ac analysis in Cadence using this equation in ADE : dB20(abs(IF("/I0/Vo"))) which Vo is output node voltage, and I0 is current related to output voltage. but always i get error that it can not calculate IF(nil). Would you please telling me what is the problem with it? Thanks alot |
Title: Re: plot current of output node in frequency domain in Cadence Post by ULPAnalog on Apr 14th, 2016, 1:29pm You are, most likely, not saving the current through the node of interest. Otherwise it will report the signal of interest as unkept. |
Title: Re: plot current of output node in frequency domain in Cadence Post by rames on Apr 14th, 2016, 11:12pm Thank you, it worked. |
