https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> why a compensator is not required for PFM mode buck converter https://designers-guide.org/forum/YaBB.pl?num=1461226875 Message started by electronics_rama on Apr 21st, 2016, 1:21am |
Title: why a compensator is not required for PFM mode buck converter Post by electronics_rama on Apr 21st, 2016, 1:21am Hello, Consider a DC-DC buck in PWM mode. Let us assume that this converter goes to DCM mode. In this scenario also, we use compensator in the loop. But, in case of PFM mode, we do not use any compensator. What is the explanation for this? I'm not understanding this concept. :-/ Thanks, Rama |
