https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> Cosmos Scope takes very long to export an image https://designers-guide.org/forum/YaBB.pl?num=1462464568 Message started by AA on May 5th, 2016, 9:09am |
Title: Cosmos Scope takes very long to export an image Post by AA on May 5th, 2016, 9:09am Hi! Exporting an image in Synopsys Cosmos Scope tool takes too long, even though it eventually works. By too long I mean about five to ten minutes. Anyone has an idea how to make exporting images work faster in this nice tool, please? Thank you. |
Title: Re: Cosmos Scope takes very long to export an image Post by Geoffrey_Coram on May 23rd, 2016, 5:41am Do you have a lot of waveforms in your image, or a lot of points in a few waveforms? I wonder if you have a lot of points, whether the export routine tries to plot every one of them, even if they're closer together than the resolution of the image you're trying to generate. |
Title: Re: Cosmos Scope takes very long to export an image Post by AA on May 23rd, 2016, 4:13pm Thanks for replying and the answer is no to both of your questions. In fact, I figured out the problem. Exporting a non-postscript format while connected to the server through X11 session results in a very long conversion time. The solution is to either choose EPS format or work on the server directly. Exporting EPS is very fast even during remote X11 sessions. |
Title: Re: Cosmos Scope takes very long to export an image Post by Geoffrey_Coram on May 24th, 2016, 7:20am Interesting! Thanks for posting your solution. |
