https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> constant current source independent of load resistance https://designers-guide.org/forum/YaBB.pl?num=1469607568 Message started by umesh on Jul 27th, 2016, 1:19am |
Title: constant current source independent of load resistance Post by umesh on Jul 27th, 2016, 1:19am Dear all, I got the circuit for constant current source using op-amp known as howland current source. I have attached the circuit diagram. I got 5.2mA constant current at variable load from 10 ohm to 5k ohm. Vin is limited to 12V and expected output current should be 8mA. Please anyone suggest me what to change in this circuit so that i can get 8mA constant current. I simulated this circuit in LTspice when i change the value of R (R1,R2,R3,R5) below 2.3k then i have getting constant current at variable load. |
Title: Re: constant current source independent of load resistance Post by vroy_92 on Jul 27th, 2016, 11:44pm umesh wrote on Jul 27th, 2016, 1:19am:
Can you please post the circuit digram? |
