https://designers-guide.org/forum/YaBB.pl Design >> Mixed-Signal Design >> Question on vco based ADC https://designers-guide.org/forum/YaBB.pl?num=1470479792 Message started by madhusmita on Aug 6th, 2016, 3:36am |
Title: Question on vco based ADC Post by madhusmita on Aug 6th, 2016, 3:36am Actually I am working on VCO based ADC in 180nm technology . I have some doubts related to that topic. 1.I am not getting the correct output after DAC when ramp and sine inputs are applied. so kindly let me know how u got the correct output 2. I have set the DAC (Vref=1,Vrise=0 ,Vfall=0,Vdelay=0,Vtran=.9) 3. I have set the clk frequency of 16.11 MHz .(vpulse period is 62ns and pulse width is 60ns) i.e reset signal to the counter 4. I have used ramp signal of duration 3.4u (when time=0s, v1=1v when time=3.4us, v1=400mv.). ADC count maximum when control volatge is .4vand minimum when voltage is 1v. Kindly suggest the time duration of ramp so that i will get correct result. |
Title: Re: Question on vco based ADC Post by madhusmita on Aug 8th, 2016, 2:16am Kindly help Its urgent.Why I am getting this type of output. How to set the parameter of DAC in cadence for 6 bit ADC |
