Simulators >> Circuit Simulators >> Error while Importing  S parameters from HFSS into NPORT in cadence-virtuoso
https://designers-guide.org/forum/YaBB.pl?num=1473780662
Message started by Shalom.123 on Sep 13th, 2016, 7:31am
Title: Error while Importing  S parameters from HFSS into NPORT in cadence-virtuoso
Post by Shalom.123 on Sep 13th, 2016, 7:31am
Hi, I'm importing s parameters from HFSS into NPORT in cadence-virtuoso.
While simulating, showing error like following.
ERROR (SFE-691) "input.scs" 61 : Illegal parameter name specified.
Simulation terminated prematurely due to fatal error.
please help me to resolve the error.
thanks.
Title: Re: Error while Importing �S parameters from HFSS into NPORT in cadence-virtuoso
Post by Geoffrey_Coram on Sep 13th, 2016, 9:01am
What's on line 61 of input.scs?
(You really haven't given us much to work on.)
Post by Shalom.123 on Sep 13th, 2016, 9:21am
please go through this......
CPU Type: Intel(R) Core(TM)2 Duo CPU     E8400  @ 3.00GHz
         Processor PhysicalID CoreID Frequency
             0         0        0     3000.0
             1         0        1     3000.0
Simulating `input.scs' on localhost.localdomain at 4:25:09 AM, Wed Sep 14, 2016 (process id: 6024).
Environment variable:
   SPECTRE_DEFAULTS= +savestate
Command line:
       /software/CadTools/cadence/MMSIMIC615/tools.lnx86/spectre/bin/64bit/spectre  \
       input.scs +escchars +log ../psf/spectre.out -format psfxl -raw  \
       ../psf +lqtimeout 900 -maxw 5 -maxn 5
Loading /software/CadTools/cadence/MMSIMIC615/tools.lnx86/cmi/lib/64bit/5.0/libinfineon_sh.so ...
Loading /software/CadTools/cadence/MMSIMIC615/tools.lnx86/cmi/lib/64bit/5.0/libphilips_sh.so ...
Loading /software/CadTools/cadence/MMSIMIC615/tools.lnx86/cmi/lib/64bit/5.0/libsparam_sh.so ...
Loading /software/CadTools/cadence/MMSIMIC615/tools.lnx86/cmi/lib/64bit/5.0/libstmodels_sh.so ...
Warning from spectre in `rnhr_rf', during circuit read-in.
   WARNING (SFE-2296): "/designPackages/design_installer/UMC/UMC180/UPDATED/Designkits/Cadence_IC6/UMC_18_CMOS/../Models/Spectre/./rnhr_rf_v2d4.mdl.scs" 8: The inline subckt definition `rnhr_rf' does not contain any inline components. The `inline' qualifier will therefore be ignored.
Warning from spectre in `rnnpo_rf', during circuit read-in.
   WARNING (SFE-2296): "/designPackages/design_installer/UMC/UMC180/UPDATED/Designkits/Cadence_IC6/UMC_18_CMOS/../Models/Spectre/./rnnpo_rf_v2d4.mdl.scs" 8: The inline subckt definition `rnnpo_rf' does not contain any inline components. The `inline' qualifier will therefore be ignored.
Warning from spectre in `rnppo_rf', during circuit read-in.
   WARNING (SFE-2296): "/designPackages/design_installer/UMC/UMC180/UPDATED/Designkits/Cadence_IC6/UMC_18_CMOS/../Models/Spectre/./rnppo_rf_v2d4.mdl.scs" 8: The inline subckt definition `rnppo_rf' does not contain any inline components. The `inline' qualifier will therefore be ignored.
Error found by spectre during circuit read-in.
   ERROR (SFE-691): "input.scs" 61: Illegal parameter name specified.
Time for NDB Parsing: CPU = 112.982 ms, elapsed = 236.045 ms.
Time accumulated: CPU = 112.982 ms, elapsed = 236.045 ms.
Peak resident memory used = 36 Mbytes.
Time for parsing: CPU = 0 s, elapsed = 14.0667 us.
Time accumulated: CPU = 112.982 ms, elapsed = 236.326 ms.
Aggregate audit (4:25:09 AM, Wed Sep 14, 2016):
Time used: CPU = 117 ms, elapsed = 240 ms, util. = 48.7%.
Time spent in licensing: elapsed = 134 ms, percentage of total = 56%.
Peak memory used = 36 Mbytes.
Simulation started at: 4:25:09 AM, Wed Sep 14, 2016, ended at: 4:25:09 AM, Wed Sep 14, 2016, with elapsed time (wall clock): 240 ms.
spectre completes with 1 error, 3 warnings, and 0 notices.
spectre terminated prematurely due to fatal error.
Post by Geoffrey_Coram on Sep 14th, 2016, 12:02pm
Please answer my question: what's on line 61 of input.scs?
Post by Shalom.123 on Sep 15th, 2016, 1:54am
Found the error in 61th line of input.scs
Thanks Geoffrey_Coram
