https://designers-guide.org/forum/YaBB.pl Other CAD Tools >> Entry Tools >> custom views in virtuoso https://designers-guide.org/forum/YaBB.pl?num=1480447399 Message started by cdg on Nov 29th, 2016, 11:23am |
Title: custom views in virtuoso Post by cdg on Nov 29th, 2016, 11:23am How do you create custom views (power point, word, Excel) in Virtuoso (what are the steps, files needed to do that)? |
Title: Re: custom views in virtuoso Post by Andrew Beckett on Dec 29th, 2016, 1:50am Typically you need to register an application with deRegApp so that Virtuoso knows what code to trigger when opening the view, and to create information about the files in the view in a data.reg file. Try searching the documentation for data.reg and deRegApp to get some more info - there will also be examples (I'm sure) on the Cadence support.cadence.com site. Regards, Andrew |
