https://designers-guide.org/forum/YaBB.pl Measurements >> Phase Noise and Jitter Measurements >> how to build pll noise model based on verilog-a using Ken Kundert�s method? https://designers-guide.org/forum/YaBB.pl?num=1484707347 Message started by lwzunique on Jan 17th, 2017, 6:42pm |
Title: how to build pll noise model based on verilog-a using Ken Kundert�s method? Post by lwzunique on Jan 17th, 2017, 6:42pm Hi,everyone. I am beginner of PLL circuit design, recently I want to do analysis about the phase noise of PLL. and I found Ken Kundert's Paper:Predicting the Phase Noise and Jitter of PLL-Based Frequency Synthesizers. there are several problems �that confuse me so much. 1.if I want to copy your code about other listings, I have to put phase.vams into the directory the same as disciplines.vams, correct? 2.I can't compile the code for divider, the detail is shown bellow. 3.suppose that I have build all the blocks correctly, what should I do to have the overall phase noise, how to connect these blocks in the schematic in candence platform, and what simulation should I do,AC or Noise? 4.if I have get the phase noise data of all the blocks made by real process like TSMC or globafoundry. how to build the verilog-a model to combine this noise data together to get the pll out's overall phase noise. thanks everybody! William |
Title: Re: how to build pll noise model based on verilog-a using Ken Kundert�s method? Post by cheap_salary on Jan 17th, 2017, 10:54pm lwzunique wrote on Jan 17th, 2017, 6:42pm:
However I recommend you to specify absolute path for "phase.vams" and place it in any directory. lwzunique wrote on Jan 17th, 2017, 6:42pm:
Show us details. lwzunique wrote on Jan 17th, 2017, 6:42pm:
See the followings. http://www.designers-guide.org/Forum/YaBB.pl?num=1275390599 http://www.designers-guide.org/Forum/YaBB.pl?num=1444923186 http://een.iust.ac.ir/profs/Abrishamifar/Analog%20Integrated%20Circuit%20Design/Hspice/Other%20Helps/Predicting%20PLL%20Phase%20Noise%20&%20Jitter%20with%20HspiceRF.pdf http://www.highfrequencyelectronics.com/index.php?option=com_content&view=article&id=1354:phase-locked-loop-noise-transfer-functions&catid=134:2016-01-january-articles&Itemid=189 |
Title: Re: how to build pll noise model based on verilog-a using Ken Kundert�s method? Post by Ken Kundert on Jan 18th, 2017, 1:13am The syntax accepted by Verilog-AMS has changed somewhat over the years. In particular, apparently the way that you give array literals has changed. So the noise table should probably be given as ... Code:
Notice the ' that initiates the array literal. Specifically, '{ ... }. Fixing that should probably clear up your syntax problem. Also notice I switched to noise_table_log. That seems like that would probably be better than noise_table. -Ken |
Title: Re: how to build pll noise model based on verilog-a using Ken Kundert�s method? Post by lwzunique on Jan 18th, 2017, 2:06am Quote:
thanks @cheap_salary and Kundert, I have fixed the error in divider block, one part of the bracket was missing. now i have built all the blocks, but the vco has no control terminal, as shown in the picture below, and I also don't know how to combine this blocks together? [img][/img] |
Title: Re: how to build pll noise model based on verilog-a using Ken Kundert�s method? Post by cheap_salary on Jan 18th, 2017, 2:17am See Listing-1. Your vco is not VCO. Read documents surely. VCO is Listing-4. |
Title: Re: how to build pll noise model based on verilog-a using Ken Kundert�s method? Post by lwzunique on Jan 18th, 2017, 2:28am cheap_salary wrote on Jan 18th, 2017, 2:17am:
Code:
In listing-1, how these definitions of the blocks know where I put the divider.va phaseDetector.va and so on? I am not familiar with verilog-a either. thank you. and when do simulation, I just simulate the single pll block in the schematic using noise analysis? |
Title: Re: how to build pll noise model based on verilog-a using Ken Kundert�s method? Post by cheap_salary on Jan 18th, 2017, 2:45am If you can not understand Verilog-A Language, can you understand Spectre or Spice Language ? If you can understand either of Spectre or Spice Language, I can translate Lisiting-1 to them. Verilog-A, Spectre and Spice are all circuit description languages. |
Title: Re: how to build pll noise model based on verilog-a using Ken Kundert�s method? Post by lwzunique on Jan 18th, 2017, 3:05am cheap_salary wrote on Jan 18th, 2017, 2:45am:
thanks@cheap_salary, I will study what your told me carefully and have a try. thank you. |
Title: Re: how to build pll noise model based on verilog-a using Ken Kundert�s method? Post by cheap_salary on Jan 18th, 2017, 4:21am Ken Kundert wrote on Jan 18th, 2017, 1:13am:
Title: Re: how to build pll noise model based on verilog-a using Ken Kundert�s method? Post by Ken Kundert on Jan 18th, 2017, 4:00pm The '{...} form is recommended in the latest Verilog-AMS LRM. It is something they picked up recently from SystemVerilog. This means that Verilog has two form for array literals, you can either use '{...} or {...}. The former represents packed arrays and the latter represents unpacked arrays. The '{...} form did not exist when Verilog-AMS first came out, so early versions of Verilog-AMS and Spectre only support the {...} form. I suspect that the more recent versions of Spectre are requiring the use of the '{...} form when specifying the array values to the laplace, zi, and table functions. -Ken |
Title: Re: how to build pll noise model based on verilog-a using Ken Kundert�s method? Post by lwzunique on Jan 18th, 2017, 7:46pm I have built the schematic as shown below,but i don't know how to get the phase noise output. I do the noise simulation, but the output curve is not as shown in the paper:Predicting the Phase Noise and Jitter of PLL-Based Frequency Synthesizers. |
Title: Re: how to build pll noise model based on verilog-a using Ken Kundert�s method? Post by lwzunique on Jan 18th, 2017, 7:51pm another problem is that, I want to simulate the noise of single VCO block, it can't work. |
Title: Re: how to build pll noise model based on verilog-a using Ken Kundert�s method? Post by cheap_salary on Jan 18th, 2017, 8:00pm You don't reflect listing-1 at all. Surely see listing-1. |
Title: Re: how to build pll noise model based on verilog-a using Ken Kundert�s method? Post by lwzunique on Jan 18th, 2017, 8:24pm really sorry for my mistake. now I think it is right. |
Title: Re: how to build pll noise model based on verilog-a using Ken Kundert�s method? Post by cheap_salary on Jan 18th, 2017, 8:36pm Do you surely set nonzero value noise ? If n is equal to zero, noise is not generated. |
Title: Re: how to build pll noise model based on verilog-a using Ken Kundert�s method? Post by lwzunique on Jan 18th, 2017, 8:45pm cheap_salary wrote on Jan 18th, 2017, 8:36pm:
I set the value of n, at now, i don't know how to set it correctly, I can get the equivalent output noise, the result is wrong. I will have further study about it. thanks for your help, and really sorry for my carelessness, I am a newbie, sometimes something is really difficult for me. thanks again! |
Title: Re: how to build pll noise model based on verilog-a using Ken Kundert�s method? Post by cheap_salary on Jan 19th, 2017, 4:34am Ken Kundert wrote on Jan 18th, 2017, 4:00pm:
There are no warning and error for both of them. And results are same. Cadence Spectre 14.1 accepts both '{...} and {...}. |
Title: Re: how to build pll noise model based on verilog-a using Ken Kundert�s method? Post by cheap_salary on Jan 19th, 2017, 4:36am lwzunique wrote on Jan 18th, 2017, 7:51pm:
Title: Re: how to build pll noise model based on verilog-a using Ken Kundert�s method? Post by lwzunique on Jan 19th, 2017, 4:14pm this figure is the phase noise of real vco. and the code is: Code:
I can't understand rad2/Hz, what is the relationship between rad2/Hz and dBc/Hz? |
Title: Re: how to build pll noise model based on verilog-a using Ken Kundert�s method? Post by cheap_salary on Jan 19th, 2017, 4:21pm Show me Spectre Netlist of giving convergence error. |
Title: Re: how to build pll noise model based on verilog-a using Ken Kundert�s method? Post by lwzunique on Jan 19th, 2017, 4:26pm vco-test schematic and the simulation log output. |
Title: Re: how to build pll noise model based on verilog-a using Ken Kundert�s method? Post by cheap_salary on Jan 19th, 2017, 4:30pm Show me Spectre Netlist. lwzunique wrote on Jan 19th, 2017, 4:14pm:
Title: Re: how to build pll noise model based on verilog-a using Ken Kundert�s method? Post by lwzunique on Jan 19th, 2017, 4:33pm cheap_salary wrote on Jan 19th, 2017, 4:30pm:
Code:
Title: Re: how to build pll noise model based on verilog-a using Ken Kundert�s method? Post by Ken Kundert on Jan 19th, 2017, 5:52pm rad2/Hz means radians2/Hertz. A VCO has no dc solution, so you should skip the dc analysis (specify 'skip dc' to the transient analysis). -Ken |
Title: Re: how to build pll noise model based on verilog-a using Ken Kundert�s method? Post by lwzunique on Jan 19th, 2017, 6:33pm in the paper: SΦ(Δf) is power density of phase, and L(Δf) is phase noise that we can get by doing pss and pnoise to a real vco, is this right? and calculation of n and fc is based on the result of pss+pnoise. how to use equation 21,26,29 to calculate n? what does the fΔ in equation 25 mean? corner frequency, is it fc? if i choose a Δf that is well above fΔ and well below fo, n=cfo^2*pi=L(Δf)*Δf^2*2,is this right? in the figure below, at frequency 10^5Hz, the slope changes from -30dB to 20 dB, so fc is 10^5 Hz. I choose Δf=100M to do the calculation. n= 2*10^(L(100M)/10)*2*(100M)^2=1.32. then veriloga model of VCO is: Code:
Title: Re: how to build pll noise model based on verilog-a using Ken Kundert�s method? Post by lwzunique on Jan 19th, 2017, 6:35pm after i changed the veriloga of vco, I mean the parameter of n and fc, the single vco block can be simulated. the result is as below. |
