https://designers-guide.org/forum/YaBB.pl Other CAD Tools >> Entry Tools >> How to use the function "infotimes" in ADE XL ? ? https://designers-guide.org/forum/YaBB.pl?num=1487040820 Message started by henryhenrytw on Feb 13th, 2017, 6:53pm |
Title: How to use the function "infotimes" in ADE XL ? ? Post by henryhenrytw on Feb 13th, 2017, 6:53pm I know how to set the "infotimes" in separate mode... like [0u 5u 10u 15u 20u] but when i need to observe a time range from 0u to 200u it is not smart to type the time from 0u to 200u with spacing 5u my friend told me a setting method... like [0u:5u:200u] his simulation can run and complete successfully but my simulation show me the error message say that " to perform oppoints, need to specify both parameters 'infoname' and 'infotimes' " why i meet this error message but he did not anything forget to set or...? ? there are other ways to reach the same purpose like "save file" but i think the method setting the "infotimes" in GUI interface is the most intuitive and convenient for me my purpose is to obeserve the MOS "region" in a range of tran simulation my virtuoso version is 6.1.5-64b thank you for answering this question :D :D :D |
Title: Re: How to use the function "infotimes" in ADE XL ? ? Post by Andrew Beckett on Feb 14th, 2017, 5:21am Which spectre version are you using? I checked this back as far as MMSIM111 (base release) and the [start:step:stop] works fine there (I couldn't so easily check earlier versions). That's quite old, so hopefully you should be able to use at least a 5-6 year old version of the tools? Regards, Andrew. |
