https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> Units showed by Smith Chart Markers of Cadence ViVA https://designers-guide.org/forum/YaBB.pl?num=1487939954 Message started by cheap_salary on Feb 24th, 2017, 4:39am |
Title: Units showed by Smith Chart Markers of Cadence ViVA Post by cheap_salary on Feb 24th, 2017, 4:39am We can use following special codes in Smith Chart Markers of Cadence ViVA. %C--Displays the real and imaginary cartesian values %Z--Displays the impedance values, such as resistance and reactance %A--Displays the admittance values, such as conductance and susceptance %R--Displays the reflection coefficients, such as mag and angle Units are showed as "Ohm" even if we use %C, %A or %R for "impedance mode". On the other hand, units are showed as "S" even if we use %C, %Z or %R for "admittance mode" Is this known issue ? |
Title: Re: Units showed by Smith Chart Markers of Cadence ViVA Post by Andrew Beckett on Mar 2nd, 2017, 3:51am I couldn't find any CCR requesting that this is changed, so I don't think it's been reported before. You should report this to Cadence via http://support.cadence.com Regards, Andrew. |
