https://designers-guide.org/forum/YaBB.pl Measurements >> RF Measurements >> Calibration Technique for RF Chemical Sensor https://designers-guide.org/forum/YaBB.pl?num=1492427964 Message started by Usman Khalid on Apr 17th, 2017, 4:19am |
Title: Calibration Technique for RF Chemical Sensor Post by Usman Khalid on Apr 17th, 2017, 4:19am Hello! I have recently finished designing of my electromagnetic resonator. It is 4 port structure using 4 circular QMSIW antennas which are isolated from each other but are constructed on the same substrate. Picture is attached My requirement is to make a calibration standard using at least 3 ports or 2 ports for calibration and then the remaining 1 port or 2 ports for chemical sensing using microfluidic channels. So, it will be a chemical sensor device using calibration standard. Can anyone please help me in how to make calibration standard in this scenario. I read some papers on calibration techniques used for moisture detection from granular materials but I did not get an idea of how to use calibration technique in chemical sensing scenario. Please help! |
