https://designers-guide.org/forum/YaBB.pl Simulators >> AMS Simulators >> ams netlisting issue using runams https://designers-guide.org/forum/YaBB.pl?num=1493969913 Message started by AMS_ei on May 5th, 2017, 12:38am |
Title: ams netlisting issue using runams Post by AMS_ei on May 5th, 2017, 12:38am Hi, I am getting an error while generating ams netlist using runams. I am using the following module: ies/15.20.014 ic/617/700 The error is attached in the file. Could anyone please help me out how can I resolve this issue? Thank you. Kind regards. |
Title: Re: ams netlisting issue using runams Post by Andrew Beckett on May 28th, 2017, 2:15pm This was fixed via CCR 1487801 in IC6.1.7.500.1 (ISR1). You're using the base release (IC6.1.7.78), which didn't have the fix. I did see a case (presumably fro you, because the content is almost identical) in which the AE (and R&D) said that the error was benign - but I thought it worth mentioning when this actually got fixed. Regards, Andrew |
Title: Re: ams netlisting issue using runams Post by AMS_ei on May 29th, 2017, 9:10pm Hi Andrew, Thank you for your valuable inputs. How can I load IC6.1.7.500.1 (ISR1)? We have the following modules available: ic/06.16.140 ic/06.17.700 ic/06.17.705 ic/06.17.706 ic/5141/ISR201102231549 ic/615/ISR15 ic/615/ISR15_ms ic/616/132 ic/616/132_save ic/616/ISR5 ic/616/ISR5_ms ic/616/ISR6 ic/616/ISR6_save ic/617/700 ic/617/700_old ic/ams ic/current ic/current_ic5 ic/current_ms ic/latest ic/prev ic/test_ms ic/xps Which module should I load to overcome the above issue? This is not mentioned in CCR 1487801. Thank you. Kind regards. |
Title: Re: ams netlisting issue using runams Post by Andrew Beckett on Jun 1st, 2017, 10:37am The CCR wouldn't mention the module you need to use, because that's obviously dependent upon what you name them. However, anything after IC617 ISR1 should be OK, and given what you appear to have called them, I'd guess either: ic/06.17.705 ic/06.17.706 would be OK. (I'm guessing those correspond to 6.1.7.500.5 and 6.1.7.500.6 - the 70x is the "release management system" naming convention on the downloads, if that's what's been followed here. Regards, Andrew. |
Title: Re: ams netlisting issue using runams Post by AMS_ei on Jun 1st, 2017, 2:44pm Thank you, Andrew for your valuable inputs. Kind regards. |
