https://designers-guide.org/forum/YaBB.pl Measurements >> Other Measurements >> Giving an input DC bias current for an IC https://designers-guide.org/forum/YaBB.pl?num=1496280320 Message started by Venky_analog on May 31st, 2017, 5:25pm |
Title: Giving an input DC bias current for an IC Post by Venky_analog on May 31st, 2017, 5:25pm Hi, I am trying to give the DC bias current to an IC from an external source. The way I am generating this current is by using a potentiometer structure shown below. ![]() By changing both VDD (tunable) and R1 (potentiometer), I can change the current. The VDD comes from an LDO and hence it's kind of accurate. The thing is I placed another series resistor R2 to reduce the variations in the current due to possible variations in the potentiometer, as I heard potentiometers are very sensitive to their environments and tend to change with time a lot. My quesiton is if I keep R2 like 25% of R1, would it be good enough? Also, is this a good way of generating current externally for biasing circuits inside an IC? Thanks in advance |
Title: Re: Giving an input DC bias current for an IC Post by kabir_fakir on Aug 30th, 2017, 3:50am For me it looks fine. I am only concerned about the thermal noise of the resistor itself as you are introducing 2 rsistors As I did testing with my IC too. to generate the dc current, I took a clean power supply (Agilent- E3644A) and put a huge resistor (in 10k range) in series with that (instead of potentiometer ). And then I keep varying the DC power supply as per requirement of the current. |
