https://designers-guide.org/forum/YaBB.pl Design Languages >> VHDL-AMS >> Hamster vhdl-ams Error : Statement is not unique https://designers-guide.org/forum/YaBB.pl?num=1501001349 Message started by loumbut5 on Jul 25th, 2017, 9:49am |
Title: Hamster vhdl-ams Error : Statement is not unique Post by loumbut5 on Jul 25th, 2017, 9:49am Hi, the following code is generating the error: :'( library IEEE; use IEEE.std_logic_1164.all; use IEEE.std_logic_unsigned.all; entity program_counter is port ( clk, en_A, ld, inc, reset: in STD_LOGIC; aBus: out STD_LOGIC_VECTOR(15 downto 0); dBus: in STD_LOGIC_VECTOR(15 downto 0) ); end program_counter; architecture pcArch of program_counter is signal pcReg : STD_LOGIC_VECTOR(15 downto 0); begin process(clk) begin if clk'event and clk = '1' then if reset = '1' then pcReg <= x"0000"; elsif ld = '1' then pcReg <= dBus; elsif inc = '1' then pcReg <= pcReg + x"0001"; end if; end if; end process; aBus <= pcReg when en_A = '1' else "ZZZZZZZZZZZZZZZZ"; end pcArch; Specifically on the line: pcReg <= pcReg + x"0001"; The error is: (ARCHITECTURE pcarch OF ENTITY program_counter) : Error : Type mismatch Please help with a fix. :) |
Title: Re: Hamster vhdl-ams Error : Statement is not unique Post by Geoffrey_Coram on Aug 7th, 2017, 6:45am I think VHDL is case-sensitive, so perhaps it should be X"0000" instead of x"0000" |
Title: Re: Hamster vhdl-ams Error : Statement is not unique Post by Andrew Beckett on Aug 8th, 2017, 1:33am I don't think so Geoffrey - VHDL is a case insensitive language... I just checked in a book I have and it says "The base specifier can be in uppercase or lowercase". Note that the module above when compiled in ncvhdl gives: ncvhdl: 15.20-s028: (c) Copyright 1995-2017 Cadence Design Systems, Inc. pcReg <= x"0000"; | ncvhdl_p: *E,EXPTYP (forum2.vhd,17|34): expecting an expression of type STD_LOGIC_VECTOR 87[8.3] 93[8.4]. pcReg <= pcReg + x"0001"; | ncvhdl_p: *E,BITOPR (forum2.vhd,21|26): This feature is allowed only in 93[13.7]. However, if I compile with -v93 or -v200x then it compiles with no problem. Regards, Andrew. |
