https://designers-guide.org/forum/YaBB.pl Analog Verification >> Analog Performance Verification >> Uses of Macro in Verilog-AMS https://designers-guide.org/forum/YaBB.pl?num=1504093701 Message started by Gp on Aug 30th, 2017, 4:48am |
Title: Uses of Macro in Verilog-AMS Post by Gp on Aug 30th, 2017, 4:48am Hi, I want to use following Verilog-ams macro for range check in cadence environment: `RANGE_CHECK(expr,"NAME", max,min,ef,en) For detailed reference, use following link: https://books.google.co.in/books?id=RKrfAwAAQBAJ&pg=PA92&lpg=PA92&dq=%60AVDD+check+in+mixed+signal+methodology+guide&source=bl&ots=uXomWUVSRy&sig=s37V_5RGMGbK0qwNuanhB1qqpJo&hl=en&sa=X&ved=0ahUKEwjq2PH27_7VAhWKhVQKHUS5CXkQ6AEINjAD#v=onepage&q=%60AVDD%20check%20in%20mixed%20signal%20methodology%20guide&f=false So, How to use this type of macro in Verilog-ams? When I use, error through about "this type of macro doesn't support". |
Title: Re: Uses of Macro in Verilog-AMS Post by Andrew Beckett on Sep 9th, 2017, 12:07am You'd have to define the macro - these are not standard built-in macros. Did you do that? The book only gives a snippet and doesn't include the definition (I don't have the actual book to hand as it's in my office, but the wording of the excerpt on the link you gave doesn't seem to show the definition). Andrew. |
Title: Re: Uses of Macro in Verilog-AMS Post by Gp on Sep 11th, 2017, 1:26am I didn't try with defined macro. And I have not idea about Verilog-AMS macro. Do you have any reference example of Verilog-AMS macro? If yes, please help me. |
