https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> Comparators input beyond supply rails https://designers-guide.org/forum/YaBB.pl?num=1510346035 Message started by niloun on Nov 10th, 2017, 12:33pm |
Title: Comparators input beyond supply rails Post by niloun on Nov 10th, 2017, 12:33pm Hi everyone I have simulated a StrongArm comparator which its inputs are beyond its supply (for instance: Vdd=0.9, Vi+=1.35+0.45*sinwt, Vi-=1.35) and surprisingly it works properly (even in the simulation corners). If it is so, why don't we decrease the supply to save power, what is wrong with decreasing the supply as much as possible for any input range? Thanks in advance |
Title: Re: Comparators input beyond supply rails Post by DanielLam on Nov 10th, 2017, 2:22pm Oxide stress. The Vgs of the input devices can also be > Vdd and runs the risk of overstressing the oxide. Btw for this nmos input comparator, the higher the common mode, the higher the input thermal noise. Also, lower Vdd will give lower speed. |
Title: Re: Comparators input beyond supply rails Post by niloun on Nov 10th, 2017, 11:48pm DanielLam wrote on Nov 10th, 2017, 2:22pm:
THanks DanielLam. I have attached two image from Razavi's survey on StrongArm. So you mean that in phase "b" transistors M1 and M2 receive an unusual amount of voltage which may cause damage to them? ![]() ![]() |
Title: Re: Comparators input beyond supply rails Post by neoflash on Nov 14th, 2017, 4:44pm If you don't need speed from the regeneration latch, you can reduce the supply to save power. Or alternatively, reduce the size of transistor at expense of larger offset. niloun wrote on Nov 10th, 2017, 12:33pm:
Title: Re: Comparators input beyond supply rails Post by niloun on Nov 14th, 2017, 11:40pm neoflash wrote on Nov 14th, 2017, 4:44pm:
Thanks, so there will be no problem if one wants to fabricate this circuit? Since I have heard about issues including : "bulk current" (which I have checked in the simulations and it was OK) or "latch up" or " oxide stress" which Daniel mentioned? |
Title: Re: Comparators input beyond supply rails Post by Frank_Heart on Nov 17th, 2017, 12:08am If your input device Vgs can handle (Vi+=1.35+0.45*sinwt), you don't have stress problem. With lower supply for latch, as DanielLam and neoflash mentioned, your dynamic gain is small and speed for latch would be low. And, how about the supply for the logics after comparator? You probably need a level-shifter to bring the voltage swing to normal supply range. -Frank |
Title: Re: Comparators input beyond supply rails Post by niloun on Nov 17th, 2017, 1:33am Frank_Heart wrote on Nov 17th, 2017, 12:08am:
Thanks for your answer Frank. You are right but we can lower the supply of the subsequent blocks and use a level-shifter in the final stage if it is necessary to have the original logic levels. Am I wrong? |
Title: Re: Comparators input beyond supply rails Post by Frank_Heart on Nov 17th, 2017, 8:19am Niloun, I agree with you. As soon as the overall speed/noise performances meet system requirements. It's a good idea to lower down supply for saving power. -Frank |
