https://designers-guide.org/forum/YaBB.pl Design >> High-Speed I/O Design >> relation between CMOS technology and speed of I/O https://designers-guide.org/forum/YaBB.pl?num=1513294123 Message started by aguntuk on Dec 14th, 2017, 3:28pm |
Title: relation between CMOS technology and speed of I/O Post by aguntuk on Dec 14th, 2017, 3:28pm I have a basic question about the speed of high-speed channel or I/O and the CMOS technology (aka gate technology). In many papers, I read people are designing or optimizing the design of high-speed channel or I/O like 40 Gbps or any data rate in 0.13 um or 65nm CMOS. In these paper, no one says why they choose that CMOS process technology of the length of the gate in um or nm or whatever. Is there any relation between the speed of I/O and CMOS gate technology? Or in another way to ask, if I want to design 40/50 or even higher Gbps of the channel for I/O what CMOS technology should I consider to implement on as a designer? |
Title: Re: relation between CMOS technology and speed of I/O Post by sheldon on Dec 14th, 2017, 6:35pm Aguntuk, Quite often SerDes are IP that are integrated onto an SoC and the requirements of the SoC designer/product determine the process to be used. The process comes into play when considering the architecture, the power, the area, ... Sheldon |
Title: Re: relation between CMOS technology and speed of I/O Post by repah on Apr 17th, 2018, 2:41pm Without design innovations, the achievable operation frequency of circuits is around fT /10. With some design innovations it is possible to design circuits up to fT /4 or in some cases ft/2. See paper: Process and device requirements for mixed-signal integrated circuits in broadband networking This is just a guide, not a general rule. |
