https://designers-guide.org/forum/YaBB.pl Measurements >> Phase Noise and Jitter Measurements >> question on phase-domain phase detector noise model https://designers-guide.org/forum/YaBB.pl?num=1516860076 Message started by tulip on Jan 24th, 2018, 10:01pm |
Title: question on phase-domain phase detector noise model Post by tulip on Jan 24th, 2018, 10:01pm Hello, I have read paper "Predicting the Phase Noise of PLL-Based Frequency Synthesizers" , and use the verilogA model descried in the paper to calculate phase noise of PLL. The paper is very useful. I have a question on phase-domain phase detector noise model listed in this paper,the phase-domain model of the synthesizer from the paper(P8, Figure4) is show below. |
Title: Re: question on phase-domain phase detector noise model Post by tulip on Jan 24th, 2018, 10:17pm in p17. LISTING 6, phase-domain phase detector noise model, I(out)<+-gain*Theta(pin,nin)/(2*`M_PI), there is a minus sign before gain, I think there should not be a minus sign before gain, am I right? |
Title: Re: question on phase-domain phase detector noise model Post by Ken Kundert on Jan 24th, 2018, 11:18pm In Verilog-A a positive current on out would flow into the charge pump. The formula computes the current leaving the charge pump. Hence the sigh inversion. -Ken |
Title: Re: question on phase-domain phase detector noise model Post by tulip on Jan 26th, 2018, 12:46am Yes, you are right, thank you very much. |
