https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> ASCO circuit optimizer usage issue https://designers-guide.org/forum/YaBB.pl?num=1532788385 Message started by blue111 on Jul 28th, 2018, 7:33am |
Title: ASCO circuit optimizer usage issue Post by blue111 on Jul 28th, 2018, 7:33am I am using http://asco.sourceforge.net/ to optimize a simple CMOS inverter for maximum output impedance. However, from the .out file, I have zrout1 = 0.00000e+00 from= 1.00000e+03 to= 1.00000e+06 Running ngspice inv.net does not give me any impression of zero impedance though. ![]() Did I miss anything else in the inv.cfg file ? |
